13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible), 123 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
#547555 06/17/2009 7:56 PM
Any help with a horn installation on 1948 Chevy 1/2 ton truck is appreciated--6 volt system. How many horns, type, where placed, and wiring detail needed. Thanks--
HONK-HONK!
Riding in the Passing Lane
The original had one horn mounted on the intake manifold wired direct. You can use any 6 volt horn or horns & mount them on the inner fenders, frame rails, or core support. I would use a relay in the system. Run the hot wire to the bat term of the relay. Run a wire from the horn/s to the horn term. Run a wire from the steering column to the button or switch term. Use 12 gauge wire on the hot lead & to the horn/s. The button wire can be small gauge, 16-18.
1972 Chevy c10 Cheyenne Super
fonz8261 #547594 06/17/2009 10:08 PM
Thanks for the info. Are there any pictures or diagrams available as well? What would the original horn have looked like? I have seen the coiled-type horns, as well as the cone-shaped horns; did it matter which one was used? I will take all the advice that I can get--much appreciated. BEEP-BEEP
The original was probably one of those big, cone shaped ones. But if you're not concerned about originality, then, as was mentioned, any 6 volt horn will work.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
