5 members (Otto Skorzeny, Gray_Ghost, Bill Hanlon, fonz8261, klhansen), 83 guests, and 2 robots.
Topics128,060
Posts1,055,833
#547129 06/16/2009 11:41 AM
Does anybody know the exact inclination of the King Pin?
I can not identify it in the online manual.
http://chevy.oldcarmanualproject.com/chevyresto/59tcc07.htm
'59 Apache
'67 Mustang
If your talking about tilting the king pin back for caster I generaly try for between 3 and five degrees. This can be done with wedges between the axle and the springs.
king pin inclination angle is measured 90 degrees from the caster angle.
It is how much the king pins lean in from vertical.
Don't have an answer, but sometimes the left and right side angles will vary a part of a degree to account for the curved surface of the road and which side you usually drive on.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
King pin inclination, or more accuratly, steering axis inclination, is the relation between the Camber angle and the spindle, with Camber being the inward lean and SIA being the outward. The dimension between the two is the Included angle. SIA is non-adjustable. If it is out of spec, that indicates a bent spindle. They should be the same on each side, withing no more than .5 degree difference.
Bill Burmeister
Well I understand the meaning of the KPI / SAI but I can not read the number. It is down in the last third of the link.
'59 Apache
'67 Mustang
My understanding is the KPI is 7 to 7.5 deg.
Dusty #547460 06/17/2009 12:38 PM
Kingpin inclination - Degrees : 6.16 - 8.18
