9 members (artinva, Gdads51, 1955 1 Series, tesa, JW51, Peggy M, VicZ, Ridgeback, 1 invisible),
93
0
Mod | | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If your talking about tilting the king pin back for caster I generaly try for between 3 and five degrees. This can be done with wedges between the axle and the springs. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | king pin inclination angle is measured 90 degrees from the caster angle. It is how much the king pins lean in from vertical.
Don't have an answer, but sometimes the left and right side angles will vary a part of a degree to account for the curved surface of the road and which side you usually drive on.
Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | King pin inclination, or more accuratly, steering axis inclination, is the relation between the Camber angle and the spindle, with Camber being the inward lean and SIA being the outward. The dimension between the two is the Included angle. SIA is non-adjustable. If it is out of spec, that indicates a bent spindle. They should be the same on each side, withing no more than .5 degree difference.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | Well I understand the meaning of the KPI / SAI but I can not read the number. It is down in the last third of the link.
'59 Apache '67 Mustang
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | My understanding is the KPI is 7 to 7.5 deg. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kingpin inclination - Degrees : 6.16 - 8.18
