| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 9 New Guy | | New Guy Joined: Jun 2009 Posts: 9 | just got a 51 coe 5700 and thought it would be nice to do an engine upgrade when the time comes.I believe a newer style 235 or maybe a 261 will work but what about the updraft carb---I know I cant use a down draft because of clearance problems. Any suggestions | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy david amerighi, welcome, there are updraft manifolds available for the later engines, they were originally for "P" vans, walk in vans, bread vans, whatever you want to call them, hope that helps. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Updraft manifold from any '50-'55 1st series Chevy COE will work. '41-'49 manifold was different. | | |
