0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#545551 06/11/2009 6:42 AM
I purchased a sheet of door panel from a local shop with the intent of fabricating my own custom panels. Then I came across a truck on ebay that used a set off of a late model Silverado and it looked great and fit really good. I just bought a set and plan on using late model power windows & latches as well and when I get them on I'll post some pics.
Robert C.
I'm a Genius in the making.
1950 3600
I have some anodized aluminum thin sheet that I picked up at 90% off at Dirt Cheap. I think I may have to use it. I will put some contact paper on the back to keep the aluminum off of the steel even though it is painted and then cover the front with something nice. I passed through Senatobia a few weeks back. I didn't see the truck. But I was looking.
robert, how late of a silverado?? I have a 2000 model that I may have to pull the door panels and put on my 52 panel smile
Looking forward to your pics.
Check your measurements and compare them with your AD. The ones I found are the rear panels from a 96-99 four model. The length at the top is 31". The height is 26.5". The bottom width is 29". The panel is not perfectly square of course so not exact dimensions. I got the idea from this video on youtube. I'm not sure what year he used. I plan on utilizing the power switches as well.
Robert C.
1950 3600
Let me know when you'll be back this way.
Robert C.
1950 3600
I did some more checking and the '03-'07 rear doors would work pretty good. They are 30x30x3-4 deep.
Robert C.
1950 3600
I must give this a try..
Moderated by  ndkid275, Phak1
