0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 45 Apprentice | | Apprentice Joined: May 2009 Posts: 45 | ok. since I just bought this truck and have no knowlegde of the differences of each part, I am goint to ask a stupid question, whats the difference between a high and low tunnel on these cabs( can I tell by hight of rise on the tunnel in inches). I want to order sound deadner and carpet pretty soon, so I figure I would consult the experts, thanks in advance | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i am no expert. the high hump came with the 4 speed and is more square, the low hump was on 3 speeds and autos and is rounder. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | a high hump should have a factory hole for the floor shifter. you can cut a hole in a low hump but it has to be bumped out a bit. that's if you are lookin to tell the difference. good luck, hr | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the othwer big difference is that one can take the h/hump out (removable). you can always install a high hump, but you need some of the accompaning sheet metal. will give you clearance also if you run a later model A/T ron | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, Found this in archives.
Does anyone have a pic of high and low floor humps as used in 60-66 trucks?
The one I got with my 61 C30 Panel is not original piece. It's about 3" tall at front, sort of square, no holes for shifter or E-brake. (but rotted at sides where it bolts to floor, so I have to figure out where to look for another.)
Thanks Pete | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We have them in stock, if you still need one. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | the othwer big difference is that one can take the h/hump out (removable). you can always install a high hump, but you need some of the accompaning sheet metal. will give you clearance also if you run a later model A/T ron I had the low hump on my 63 C10. I was able to put a TH-400 in without any clearance problems. I don't know about anything later. My 62 C10 has the high hump. It is required for the 4-speed. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there is also a high hump with no shifter holes at all that is removable. it comes from the 60-62 gmc that utilized the old hydramatic trans. if any requires a pic just ask ron | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Thanks guys. Now I know for sure what they look like and where to look for one. 60-62 GMC with hydramatic? Oh boy, not exactly the easiest thing to turn up!
Pete | | |
