2 members (mick53, J Lucas),
133
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Thinking about setting up another alternator on my 292 to feed a second 12V system for the home parts of the Grumman RV.
I have a spare groove on the crankshaft pulley. Any tips on brackets and such for an installation? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a splitter that lets the alt charge 2 bats. but only one is used for running the vehicle. Most RV's & service trucks use this system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I think it is called a battery isolator. I had one on my 84 pickup to power my cabover camper. All you need is another batter the isolater and a place to mount the extra battery. The way it works is as you drive, the alternator charges the main battery. Once it is charged then it charges the second battery. As the name indicates it also isolates the two batteries, so you always have a charged battery. | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | My inverter peaks at 5KW, so I need a large battery bank AND alternator to power it, more than the present alternator and battery can handle.
This machine already has 3 power systems on board; a 12VDC engine and running gear system, a 12VDC "house" system and a 120VAC "house" system for shore power or generator.
Separate systems will allow the most flexibility. A few brackets and minimal wiring, and it is done. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | It would be a lot simpler to upgrade to a large single alternator, maybe a 200 amp capacity, or something similar. Check into adapting your existing mounting system to allow you to install an alternator like a tractor-trailer system would run. It's virtually impossible to have too much amperage capacity, as the battery will only accept enough current to charge itself. Once both battery banks are fully charged, the regulator will cut the alternator back to a minimum charge, no matter what the upper current limit might be. When I ran a diesel shop service truck, I had an 8D series 12 volt battery that weighed about 120 pounds, and a 200-amp brushless alternator. My booster cables were made from 1-0 welder cable and would carry over 1,000 amps. Boost-starting a big rig was no problem! Jerry
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i had to make my brackets when i put a gmc top kick alt on my 292 it had the heavy duty bearing's and regulator .model 21si 100amp #1117886 i just used a good used one and changed the pully .here is a sample http://www.motorcityreman.com/deoe1111111113.html
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | in my 66 with a 292 i always had two heavy duty batteries. i have had them hooked up parallel, i believe, without the isolator and then with a a switch to chose the battery. the reason i did was the heavy winch i had. i just had the stock 60 amp alt i think. i now have just one battery with a 100 anp alt in my 64 with the same winch. any way i have had it it would drain the battery/batteries with the engine running with much use. i think everyones ideas about just a single heavier amp alt is best. i just had to learn to pace myself, not much help huh.  | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | I run a large case one wire that will sustain a true 180 amp. under const. load to two 27 series batts in parallel ( I do not need the iso for back up) ran lights fans TV and frig for 14 days after a tornado hit our property 5500 with a boost of 6800 inverter | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Then running a 5000btu AC and a mini frig from the inverter while driving should be no problem! Any tips on selecting the right alternator, or is it a standard item?
Seems like I remember reading that the 292 has a longer shaft on the alternator... | | |
