3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#546730 06/14/2009 11:49 PM
Hi, i was wondering if anyone here has used a chev. 14 bolt rear when converting to an open drive line? My specific concern(question) was if the pinion offset created a problem with vibration and u-joint wear. Any input would be appreciated.
50' chevy 3100 shortbed
jhannigan #546754 06/15/2009 2:22 AM
How about some information? What vehicle, what are your plans for it?
~Jim
The 14-bolt comes is two versions, a full-float and a semi-float, and the full-float comes in at least two distinctly different widths.
The 14-bolt under my '55 1st GMC looks to have the pinion exactly centered under the frame.
The project isn't finished so I've not experienced any problems like you mention. At least not yet...
old sub and big chevy thanks for your replies. My truck is a 50 1/2 ton. I have the 9.5" 14 bolt with 65" width. From what I have gathhered on some drive line forums
all 12,and 14 bolts are offset. the axles are equal and the diff is centered, but the pinion is offset 1/2" to the right. I also checked the spicer link in the tech tip section. I believe the offset is well within spec for compound angles, but was wondering if anyone currently had one running. Thanks again, any info, opinions are arrpeciated
jhannigan #546814 06/15/2009 4:38 AM
Take a look under a 55 Chevy passenger car sometime! The pinion is offset at least 2" from the centerline of the frame, and millions of them were produced. I have no idea why that was done, but a driveline can handle some pretty radical side-to-side deflection without any problems.
Thanks for the post Hot Rod Lincoln,
I'm feeling better that the offset won't be a problem. I appreciate all the replies
