| | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Hi, i was wondering if anyone here has used a chev. 14 bolt rear when converting to an open drive line? My specific concern(question) was if the pinion offset created a problem with vibration and u-joint wear. Any input would be appreciated. Thanks, John
John 50' chevy 3100 shortbed
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | How about some information? What vehicle, what are your plans for it?
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 14-bolt comes is two versions, a full-float and a semi-float, and the full-float comes in at least two distinctly different widths.
The 14-bolt under my '55 1st GMC looks to have the pinion exactly centered under the frame.
The project isn't finished so I've not experienced any problems like you mention. At least not yet...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | old sub and big chevy thanks for your replies. My truck is a 50 1/2 ton. I have the 9.5" 14 bolt with 65" width. From what I have gathhered on some drive line forums all 12,and 14 bolts are offset. the axles are equal and the diff is centered, but the pinion is offset 1/2" to the right. I also checked the spicer link in the tech tip section. I believe the offset is well within spec for compound angles, but was wondering if anyone currently had one running. Thanks again, any info, opinions are arrpeciated
| | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Take a look under a 55 Chevy passenger car sometime! The pinion is offset at least 2" from the centerline of the frame, and millions of them were produced. I have no idea why that was done, but a driveline can handle some pretty radical side-to-side deflection without any problems. Jerry
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Thanks for the post Hot Rod Lincoln, I'm feeling better that the offset won't be a problem. I appreciate all the replies
