| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I purchased a sheet of door panel from a local shop with the intent of fabricating my own custom panels. Then I came across a truck on ebay that used a set off of a late model Silverado and it looked great and fit really good. I just bought a set and plan on using late model power windows & latches as well and when I get them on I'll post some pics.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I have some anodized aluminum thin sheet that I picked up at 90% off at Dirt Cheap. I think I may have to use it. I will put some contact paper on the back to keep the aluminum off of the steel even though it is painted and then cover the front with something nice. I passed through Senatobia a few weeks back. I didn't see the truck. But I was looking. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | robert, how late of a silverado?? I have a 2000 model that I may have to pull the door panels and put on my 52 panel  Looking forward to your pics. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Check your measurements and compare them with your AD. The ones I found are the rear panels from a 96-99 four model. The length at the top is 31". The height is 26.5". The bottom width is 29". The panel is not perfectly square of course so not exact dimensions. I got the idea from this video on youtube. I'm not sure what year he used. I plan on utilizing the power switches as well.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I passed through Senatobia a few weeks back. I didn't see the truck. But I was looking. Let me know when you'll be back this way.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | robert, how late of a silverado?? I have a 2000 model that I may have to pull the door panels and put on my 52 panel  Looking forward to your pics. I did some more checking and the '03-'07 rear doors would work pretty good. They are 30x30x3-4 deep.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | | | |
