| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | just wondering if my holley 750 would run on my chevy 261 with the clifford 6=8 intake manifold for 4 barrel carbs? Thanks Danny | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | No. Probably not well. Holy overcarburetion, Batman.
CFM=Displacement x redline rpm/3456
With that, I get 264 cfm requirement at 3500 rpm.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Have you reviewed posts on this issue in both the "HPo" and "Engine & Driveline Shop" sections? This question is one of the most commonly ask questions on this forum. I would pay attention to posts by 'Carbking', as he is in the carb business and is a 'Guru' on this subject, not to discount others who have "been there, done that". Good luck.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I'll add something else, since it's easier to just answer the darn question than to make the guy do a bunch of searches for topics.
I used a really good 2-barrel carburetor on my 235 that might work for you. I got it from Langdon's Stovebolt, and it was a Holley-Webber carb. It had two bowls and took two jets, one a primary and one a secondary, and had a progressive linkage. The carb was real cheap, as was the adapter and linkage kit. I suggest buying everything Langdon offers since it's all engineered to work together and it works really well.
Your only task is to get the right jets. Those jets are not sold by Holley anymore but I may have a few if you end up going this route. What you'll want to do is solder the hole of the brass jet closed and then use a precision drill bit to drill your own sized hole until you get your carb about the right air/fuel mixture, which you can see from looking at your exhaust pipe emissions and spark plugs.
I'm sorry but I don't remember what size I started out with. But I want to say it was about like a standard #52 Holley jet on the primary and maybe a #58 secondary. But then again I was at a mile altitude.
The carb made a LOT more torque, and I got an extra 600 rpm on the top end too. So it ran very well.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | alright.thanks a lot.ill look in to the langdons stovebolt carb. | | |
