0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 | I'm placing my motor back into my 53 chev and and hooking up my shift linkage, here's were the problem begins. I installed a Fenton dual intake and now see that the shifter box linkage hits the intake has anyone else come across this problem and maybe has a solution for me? Does the linkage have to be modified? Thanks in advance | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Interference is a given in column shift trucks. You might be able to simply shorten the arms for clearance but be aware that will alter the throw of the shift arm inside the cab. I cut mine and tacked in flatbar extensions to reach under the intake but it took several attempts before I found an arm geometry that worked to my satisfaction and then I welded them solid. Here's a pic: http://s176.photobucket.com/albums/w186/curt160/mods/?action=view¤t=shiftarms.jpg
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jason,
The 3-speed shifter rods/arrangement is slightly different in my 1954 truck in comparison to earlier years. Last summer, I put in a Fenton dual intake and, at first, one of the shifter rods rubbed against the intake. After adjusting the rods, the rod no longer rubs.
Tim
| | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 |  Thanks Guys I'm going to modify them! I just wasn't sure if I needed change the design or simply hack off the end and re-drill. I sure am glad I can ask somebody these questions. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | In order to keep the shifter throw length from getting too long, you'll need to re-drill the hole at the other end of the linkage as well. You don't have to cut the other arm shorter though. Just move the hole so that the distance from the pivot point is proportional.
regards, Leon | | |
