5 members (3B, Otto Skorzeny, 55shaker, rick46ia, 57 Drifter), 73 guests, and 1 robot.
Topics128,023
Posts1,055,365
Members48,420
#54488 01/04/2006 11:14 PM
Riding in the Passing Lane
I,m putting a small block v-8 in my 55-II in replace of a 6. The exhaust manifold runs right into the gearshift linkage. I put one in a 56 2years ago & never had a problem. Also it has a bellcrank on the bell housing that wasn,t on the last one I did. Can someone tell me the difference. I,d like to keep the column shift. :confused: Thanks. George
1972 Chevy c10 Cheyenne Super
#54489 01/04/2006 11:33 PM
George are you using a center dump ram horn exhaust manifold, as I get older memory fails a little but when I put a 350 in a 55 2nd years ago I think that is what I used.
jim
#54490 01/04/2006 11:55 PM
I,m using ramhorns with straight down outlets. This lever comes so close to the #7 port there is no manifold that will work.
#54491 01/05/2006 8:59 AM
Do you think a header system would squeeze in there? My 90 MK VII came with tubular headers from the factory on the 302 v8 and it was a quiet car so don't worry about noise.
Kind of scarey when you don't know as you are one of our best information sources Mr bender! smile
#54492 01/06/2006 9:18 PM
I solved it. I went to my partners salvage yard & looked at some others. It seems the 56 up & 55 v-8 has different linkage. The levers are shorter & the 2-3 is curved up. I got the whole system off a 58. Thanks for the replies. smile
#54493 01/07/2006 6:27 AM
I solved a clearance problem once by flipping the shift box and levers to the left side of the column. The shift pattern is backwards but worked fine on a 1932 Chev. coupe with a 1940 column shift. Also could shorten the shift shaft and move the shift box farther up on the column. There are no insolvable problems only some are so complex it's not worth the trouble. Stay at it, you'll figure it out, I did.
