Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (greenie-reddy, TIM ZINDLER, Bill Hanlon, Rusted Nut, 50Chevy3100, DennisM, 1 invisible), 153 guests, and 3 robots.
Topics128,278
Posts1,058,581
Members48,492
Does anyone know if the tiny tube going to the oil pressure gage on my 46 chev is flared? If so is there a special tool used to form the tubing?
Jimbo's46,
I don't know for sure...most tubing, especially small stuff like 1/8" is not flared but is sealed with a brass ferrule and a compression nut. If you have the fitting from the block, it will tell you the whole story. It would have a female opening the same size as the tube OD, as the tube fits into this fitting.
Stuart
Mine is sealed with a brass ferrule and a compression nut. Don't know if it's the original setup but that's what I put in and it works.
