2 members (Guitplayer, Lostbuthaulinass), 136 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#544131 06/06/2009 3:44 PM
What keeps the tailgate and hinge from rubbing paint-on-paint when the tailgate is opened? Is there a part I am missing that separates the two?
Dan,
Nope there was nothing in there from the factory, just metal to metal and yes it rips the paint off in short order.
I used some clear vinyl stone chip tape like ya get for rocker panels and bed corners & cut it an wrapped it around my hing to keep some cushion between the 2.
Just a tip.
Tim
1952 Chevy Shortbed
Photos in Photobucket
I'm hoping that plating them and using a strip of thin gasket paper with a bit of grease will prevent that and it's working so far. A thin plastic bushing that fit the tailgate hole would be a good find. If you buy repop hinges be sure to fit them to the tailgate before painting as some variation will be present.
You Tube
Thanks guys. I think I like the plastic bushing idea since it should be more substantial long term. We have a local hardware chain that seems to carry some really unusual hard-to-find items. This might be an opportunity for a budding entrepreneur.
all US metal
if ya use it ........ the gasket paper will last till it's worn, about a doz + times....... eek
throw a dab of grease on the hinges b4 you put her back together
i use rubber bicycle inner-tube for the chain
or
completely redesign it using delrin or UHMW [ultra high impack machinable] plastic headscratch
Jim & Caroline
I made my on latch and steel strape hinges that hide inside the tailgate when closed. They also sell them through Mar k. I will try to post some pics tommorow if time.
