| | | Forums66 Topics128,156 Posts1,057,017 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I have my cab on my rotisserie and spent the first day just moving it to observe it in different positions. I didn't quite get the center of gravity right but it"s very close. I've added patch panels to the front corners and have the cab turned so I can work on the bottom. In cleaning off the undercoating got to thinking which would best protect the floor pan. Would like input as to which is best undercoating,bedliner,POR, or Eastwood encapsulator. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | if you have the money to do this i would go with rhino lining on the bottom you will never tear through it and will last longer then the truck itself  not that you would ever need it but its also semi-bomb prof
1937 1/2 ton
| | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Thanks for the reply, was wondering why more people don't use a bed liner, does it keep the moisture out or does it just protect from physical scratches. Should one first protect with a good rust encapsulator and then add the bedliner? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | just a thought, if you are rotisserie restoring it, will you ever drive it in bad weather? my experience with undercoating has all been bad, usually traps moisture and causes rust instead of preventing it. I would recommend a good prep, primer and maybe a rust preventing paint, unless you have some imperfections you want to hide with undercoating. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I agree with 53monster....What conditions will you be using your truck in? As far as scratches are concerned, I wouldn't worry.... It's unlikely it'll get scratched unless you or someone else isn't careful when working on/around it. Here's what I did with mine POR-15 is as tough as old boots and although it's UV sensitive,if it ever sees the sun,it means i've got bigger problems to worry about! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have used Herculiner bed liner and if it is applied correctly will not hold moisture. It is painted on just like paint and adheres as well or better than paint. http://www.herculiner.com/
~Jim
