8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i'm in the market for a new 235 block for my truck. i have found a few but they are not in running condition or removed from the vehicle so i cant verify the condition of the water jacket. i plan on rebuilding the engine so the condition of the bearings and such is not that important to me. the conditon of the block itself is.
i know to look for a "lip" on the top of the cylider. i have also been told that the water jacket often cracks on the driver's side so i could look there for an obvious crack.
are there any other key items/areas to check?
thanks
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are paying good money for a local, used block, buy it on the condition that it is not cracked (note the engine serial number on the bill of sale). Then have the block cleaned and checked for cracks and for "rebuidability".
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | thats a good idea. i'll see if any of the sellers will go for that.
most of the blocks are pretty inexpencive but i dont need a useless block in my yard. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | most won't go for it, unless they are asking too much for it in the first place. anything with "insurance" you will prob have to pay for it. i would just use the unknown factor to try to get it as cheap as possible. remind the seller of it may be junk several times as you are bartering. in the end you prob will just have to roll the dice till you get it checked. it's always irritating to pay for somethng and do several hours of work just to find it's no good, such is life. | | |
