0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 16 Apprentice | | Apprentice Joined: Mar 2009 Posts: 16 | I was wondering if 1 of U Knowledgable guys could tell me how innerchangable and avaiable are the gears in a 57 6500 2spd rear axle. What I was wanting to know if possible is can you get 1gear around @3.00? (Decent city and Hiway gear) Then a even lower gear @ 2.00? (Like a overDrive) Thinking about making a car hauler with 396 4spd (Granny low) Is this even possible? How about newwer 2 spd rearends?
Any help is appreciated.
"Then again the WIFE could be RIGHT Just Cause I drink alot of BUD that don't make me WISER"
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | you would have to have a lot of torque to pull a 2.00 gear(Haven't run across a gear that tall yet myself) otherwise you would likely have to downshift for a pebble in the road. Modern diesels are running in the low 3's but they have 1600 t0 1800 lbs of torque. | | | | | Joined: Mar 2009 Posts: 16 Apprentice | | Apprentice Joined: Mar 2009 Posts: 16 | I quess what I'm asking are these 2 spd rear axles made where you could swap out the gears, to get a decent over drive atleast when your driving through the flats of Kansas. or should you be doing the gear changing in the transmission.
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Look up Mike B (Mike Boteler) here in the forums (do a search) and then ask him about his gear swap in his Task Force Fire Truck. I forget off hand what he did, but whatever gearing he swapped into his rear axle lowered his ratio to where he runs 65 -70 MPH (I couldn't outrun him on the 700 mile trip to Huntsville and back, that's for sure -- I was in a '95 Cummins Dodge and just over 18,000 lbs gross).
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If it has an Eaton 2 speed, different rears that interchange, but there were no fast ratios in that period. If you are putting in a 396 you could pull faster gears. This can be accomplished by either using a 5 speed overdrive or a complete rear end out of a late model truck. Our over the road trucks have the high twos with a direct and the low threes with an od transmission. However their torque rating is at 1200 rpm and we have the governor set at 1700 rpm. These engines weigh 4000 pounds and simply won't work in your application. You can use this calculator to determine your road speed. http://www.free-online-calculator.c...d_calculator/road_speed_calculator.shtml | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | 57ExtCab, If you have the Corporate GM 15,000# 2-speed rear with vacuum shift (which I bet you do), than the "standard" rear ratio used in the TF trucks was 8.72/6.40:1. The parts book has a faster set of gears listed that are 8.39/6.17:1, but I've never seen this gear ratio...don't know what they came in. How fast are you look'n to go? Any thing faster than about 65-70 and your out running you brakes if they are stock. Installing a OD trans or by adding a OD unit like Gear Vendors or US Gear make might be easier to do. Mike B  | | |
