3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#543688 06/05/2009 2:44 AM
I took my 51 3100 on about a 30 mile round trip to a cruise in. This is the farthest I have driven it since I've owned it. (Only a few months) I noticed that at partial throttle I have what can best be described as a rattle. From the cab it sounds like it is toward the back of the engine. When I let off the throttle it goes away and when I accelerate it goes away. I have good oil pressure. I experimented with pushing in the clutch to see if it was related to the clutch but with the clutch pushed in it still makes the sound.
Sorry for the long post. Any ideas are appreciated.
Sincerely,
Chris
I would check and see if somthing is loose, air cleaner , inner fender , motor mts ,rear mts , oil filter can , starter ,EM brake rods , just shake stuff and You might find somthing that is loose and at a certain RPM it will vibrate and make noise.
Pete
Hi Chris, sounds like you have something loose under the truck, I would check the exhaust system first. Next I would do a hand check of all things under the truck and engine compartment, you are looking anything loose that moves with the engine.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
hippy #543756 06/05/2009 5:04 AM
Rod bearings knock on what is called the float, between accelerating and decelerating.
My Blog
What are the remedies for rod bearing knock? Do I need to worry about driving the truck?
Id be worried if my 216 didnt rattle. grin
Let us know what you find.
My 1953 Chevrolet
1947.1 Gallery
If you "throw a rod", it could ruin the block.
It sounds like it's time to drop the oil pan off and take a shim out of the rods to close up the oil clearance a little. Use some Plastigage and try for 2 thousandths or slightly less clearance.
Hi, Chris, I reread your post and remembered when I got my truck, it would rattle, ping ect.until I set the timing right.So for a quick check retard the timing a few degrees and try that.Use the octane gage at the base of the distributor for adjustment. Loosen the distributor and turn toward negative a little, try that and see how it runs.
