3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
I have the fresh air heater in a '49 pickup and my truck has been converted to 12v
Is anybody aware of a motor that will fit the stock arrangement?
Thank you,
Ray
I used the one from www.ClassicParts.com stock code #68-009 about $40. The other option is Grainger if you take your old one in they can usually match it. This swap requires a bit of modification. The orginal fan needs to be drilled out. You have to massage the mountings and trim the motor bolts. With a replacement motor you will also need to run a ground connection to the firewall. Mine works great, here are some after pictures.
http://community.webshots.com/photo/2080453290102454676JaBKGQ
http://community.webshots.com/photo/2721657400102454676GytrQt
http://community.webshots.com/photo/2392176610102454676KUtsLh
took my old one to autozone years ago.matched one up .it was like $21.00.........................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Great, looks like I'm set.
Thanks guys
