| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | I have a 54 eng. w/press oiling system and the full felpro gasket kit comes with two diff. sets of oil pan rail gaskets one has a straight hole pattern wich is not for this eng. the other is stagard and may be it tryed many diff combinations the closest still has to be moved around and tacked in place to fit any ideas ? | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | True to your handle, try "eliminating" the gasket altogether. Use Permatex "The Right Stuff". It is a rubber elastomer, not silicone or RTV. Get the kind that comes in a tube that will fit in your standard household caulking gun. It will take 3 minutes to apply and you are good to go. It is OEM on some Catepillar engine oil pans, according to what I have been told. The oil won't seep around the bolt holes like you get with standard gaskets and cement. | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | thanks. Thats what I do (use) on all my street rod and offshore eng. just slipped my mind
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1954 235 or 261 takes the straight gaskets. 1955 second series 235 or 261 takes the one that has an angle incorporated in the gasket. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | | | |
