1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 21 Apprentice | | Apprentice Joined: Apr 2009 Posts: 21 | I'v just begun working on this truck. It's a '63 1/2 ton, 6 cyl. I noticed that the wire going to the bottom connection of the voltage regulator is missing. I don't have a wiring diagram for this truck yet. What color wire am I looking for? Wouldn't it come out of the main wiring harness on the driver's side?
Joe '63 C10
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Go to www.rowand.net, the guy has all kinds of tips and advise on his page. There is even a wiring diagram for a generator that may help. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joe, Not sure what wire you are referring to, but here is a link to a wiring diagram for a '63 with six cylinder engine. Hope it sheds some light on your problem. http://rmcavoy.freeshell.org/diagrams/63engine_6.jpgStuart | | | | | Joined: Apr 2009 Posts: 21 Apprentice | | Apprentice Joined: Apr 2009 Posts: 21 | Excellent! Thanks guys. I should be able to figure it out from here.
Joe '63 C10
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the bottom wire that's part of the 4 prog connection? it goes thru the round main plug on the drivers size. | | | | | Joined: Apr 2009 Posts: 21 Apprentice | | Apprentice Joined: Apr 2009 Posts: 21 | Okay, I found it. A brown 20 gage wire. Re-connected it to the voltage regulator. Guess what? My battery charges now. Sweet! Thanks for the help, especially the wiring diagram.
Joe '63 C10
