4 members (DaveV, 1955 1 Series, dunfire, Dragracefan), 115 guests, and 2 robots.
Topics128,150
Posts1,056,821
Members48,456
#543022 06/02/2009 9:54 PM
I'm installing a side fill tank under the bed in my '49 - 3100.
I want to use a round pop out door like on the late model chevy pickups / suburbans.
Can any one give me dimensiond from the wheel lip & top of the fender for whete to mound the filler door ?
Thanks.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
nvrdone #543662 06/05/2009 1:06 AM
Wouldn't you go ahead and source your door and your tank, then given the rubber connector (flex) hose between the two, decide the best fit on your truck? Sorry if I am missing something, but I am thinking it will be where ever it needs to be depending on your aftermarket tank and where it comes out in your fender, plus the size of the door.
If I had a donor vehicle I'd cut the area around the actual door and what I cut out of the original fender would be larger than just the door. I'd MIG in the door and surround after cutting to fit.
But again, I may be missing something. Good luck.
R-Bo
1966 GMC 305V6 in the family
