0 members (), 79 guests, and 0 robots.
Topics128,035
Posts1,055,560
#543391 06/04/2009 4:21 AM
I finally found a complete cab for my 56 smile.
As expected there is some work needed 1 hinge pocket, 1 toe & rear corners...But it came with... 2 doors fair condition(still mounted hinges good shape),2 fenders, one needs a rear patch, a complete reupholstered seat, all the glass...and misc small parts....$500 local salvage yard smile
brsdb3381 #543395 06/04/2009 4:26 AM
Sounds like a good deal to me.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan's 57 #543412 06/04/2009 4:58 AM
How is the best way to remove the steering arm. What tool is required? Will a late model puller work or is it something special? Pulling column prior to cab comimg off frame.
While Im at it what about rusted brake & clutch pedals.....
Brad
PS asked same question in driveline shop not sure where to put it so I did both.
Brad
brsdb3381 #543512 06/04/2009 4:00 PM
Brad, this sping I started My restore on a 52-3100 and You do not have to pull the steering arm to remove the box just remove the 4 or 5 bolts holding it to the frame and turn it as you are sliding the colum out of the cab , rusted bolts I use rust free and than a impact with a 6 point impact socket if it a smaller bolt or nut I turn the air pressure down a little if it does not move, go one way than the other . I have started to blast all My small parts using a blast cab from Grainger than I paint them with Rust Stop primer from Ace and than paint with Rust Stop top coat the color I need ,it takes alot of time but now I go in the garage and see fewer and fewer parts all rusty and boxes of painted parts ready to install when the time comes {no time soon} Have fun, Pete
