0 members (), 82 guests, and 2 robots.
Topics128,090
Posts1,056,378
Members48,442
Hi Everybody,
I haven't posted in years since I bought a basketcase 54 Chevy 1/2 ton, realized I was WAY over my head, and promptly sold it for a loss.
Now I'm back, and I just bought a 1957 Chevy Pickup, 3100, Stepside. Everything looks pretty original except for the engine. The previous owner put in a 327. It runs, but there is no way to drive it because the previous owner removed the shift linkage.
It had 3 on the tree, but the previous owner wanted to put in an automatic tranny. He started by removing all the shift linkage from the column, but that's as far as he got, because his health failed and I ended up picking up the truck for pretty cheap.
The truck has still got the 3-speed transmission and I figure I'll just reassemble the shift linkage he removed and keep the tranny that is in there now.
It looks like I have all the parts that he removed, but I have NO idea how they all go back together. All The pedals are removed, and the shift linkage from the shifter down the column to the tranny is removed as well. All I need to do is re-assemble it, but I'm pretty confused by it all.
Does anyone have any photos/diagrams/copies from a book that I can look at to reassemble this shift linkage and put the pedals back in?
The motor starts and runs fine, but I just can't put it into gear. Any tips would be greatly appreciated.
Thanks everybody,
Joe
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
2003 Harley Davidson
Several people have assembly manuals here, mine only does the 60-66 eras. I'm sure they will be along soon,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks Scott,
Hope someone out there can provide me with a schematic or something . . .
I'm usually pretty good at re-assembling things if I am the one that takes it apart, but if someone gives me a pile of parts on something I'm not familiar with, I'm totally in the dark . . .
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
a lot of it is shown in the shop manual, including the adjustment - try this.... the joint piece on yours will be a bit higher up the column than the 55 shown, but easy enough if you lay it all out and go slow wink
Thanks . . . I'm going to lay out the parts and see if I can get this thing back together.
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
