| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54314 01/02/2006 6:56 PM | Joined: Dec 2005 Posts: 50 New Guy | | New Guy Joined: Dec 2005 Posts: 50 | [img] http://lyndonjscott.com/freelancejobs/truck/timingmarks.jpg[/img] I need to crank the engine over a little some that I can get to the bolts to take out the cam - I just realized this as I was starting to take the bolts off of the rockers. Do I need to pull the harmonic balancer off of the old engine to put it on the new one to do this? | | |
#54315 01/02/2006 6:59 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How about putting a bolt in the crank and turning it with a wrench? Use a bolt short enough it won't bottom in the hole, and use a large washer to protect the crank.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#54316 01/02/2006 7:06 PM | Joined: Dec 2005 Posts: 50 New Guy | | New Guy Joined: Dec 2005 Posts: 50 | thanks for the help.
I was going to try that last night, but didn't have the right size bolt. Do you know what size the bolt should be? | | |
#54317 01/02/2006 7:25 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you have no threads to stick a bolt in, pull the crank gear. Then you can rotate the cam. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#54318 01/02/2006 7:36 PM | Joined: Dec 2005 Posts: 50 New Guy | | New Guy Joined: Dec 2005 Posts: 50 | pull the crank gear - how? | | |
#54319 01/02/2006 8:42 PM | Joined: Dec 2005 Posts: 50 New Guy | | New Guy Joined: Dec 2005 Posts: 50 | thanx - turned it over from the flywheel end. | | |
