1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | I'm installing a side fill tank under the bed in my '49 - 3100. I want to use a round pop out door like on the late model chevy pickups / suburbans. Can any one give me dimensiond from the wheel lip & top of the fender for whete to mound the filler door ? Thanks.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Wouldn't you go ahead and source your door and your tank, then given the rubber connector (flex) hose between the two, decide the best fit on your truck? Sorry if I am missing something, but I am thinking it will be where ever it needs to be depending on your aftermarket tank and where it comes out in your fender, plus the size of the door.
If I had a donor vehicle I'd cut the area around the actual door and what I cut out of the original fender would be larger than just the door. I'd MIG in the door and surround after cutting to fit.
But again, I may be missing something. Good luck.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
