| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 62 | I am converting my '56 3600 to a drum drum power dual master cylinder setup. has anyone used the firewall kit instead of below the cab, any benifits besides dirt. it is a 235 six. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I can't see any benefit. If you have a stick shift you will have one pedal through the floor and another hanging from the firewall. There are lots suppliers with a wide range of brackets, boosters, MC's & kits available to incorporate your existing pedals. You will still have to run some new lines with either set up. Fred
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | There is only one benefit that I can think of and that is it would be easier to fill the MC. But, many disadvantages. Besides I think they clutter up an engine compartment. | | |
