0 members (), 134 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,456
old truck heaven
old truck heaven
Hi Fellow stovebolters.
I have acquired a 1946 Chevy 1-ton panel.
I would like to mount a passengers side seat which I have found and purchased. The seat has the mounting bracket attached to the seat....but where do those mount to on the floor? Id there some additional hardware or brackets needed? Does anyone have a photo they can email me?
Brian
old truck heaven
old truck heaven
Bump....still looking for the info......does anyone have a 1941-1946 panel truck with the correct accessory seat so they can advise me?
Thanks for any help.
Brian
I put a bench seat from a pick up in mine, so I can only guess on the real set up. Would a seperate set of seat rails work? Is there a suburban jump seat that would have the same mounting?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
old truck heaven
old truck heaven
Hi MikeE.
I did get the seat mounting figured out. I am working on the rear bumper brackets....the pieces that mount directly between the bumper and the bracket that mounts to the frame. Could you take a photo of yours and email it to me at [email protected] ?
Thanks in advance
Brian
Brian;
Mine has a home made bumper that is welded to the frame. I have some brackets and a bumper to put on and I think they just bolt to the frame.
Mike
1946 1-ton Panel
