3 members (jay d, TooMany2count, 1 invisible),
89
Mod | | | Forums66 Topics128,139 Posts1,056,754 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Fellow stovebolters. I have acquired a 1946 Chevy 1-ton panel. I would like to mount a passengers side seat which I have found and purchased. The seat has the mounting bracket attached to the seat....but where do those mount to on the floor? Id there some additional hardware or brackets needed? Does anyone have a photo they can email me? Thanks Brian | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Bump....still looking for the info......does anyone have a 1941-1946 panel truck with the correct accessory seat so they can advise me? Thanks for any help. Brian | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I put a bench seat from a pick up in mine, so I can only guess on the real set up. Would a seperate set of seat rails work? Is there a suburban jump seat that would have the same mounting?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi MikeE. I did get the seat mounting figured out. I am working on the rear bumper brackets....the pieces that mount directly between the bumper and the bracket that mounts to the frame. Could you take a photo of yours and email it to me at [email protected] ? Thanks in advance Brian | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Brian;
Mine has a home made bumper that is welded to the frame. I have some brackets and a bumper to put on and I think they just bolt to the frame.
Mike
