1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 17 Apprentice | | Apprentice Joined: Jan 2002 Posts: 17 | I removed the 5 screws along the top and center of the grill but it is still attached to a plastic piece below the grill. How is it attached and how can I release it? I need to remove the grill to gain access to the A/C condensor.
Kenneth L. Hollingsworth
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | You may want to ask over on ChevyTalk since they deal w/late model trucks also...Joe | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | My 96 Blazer snaps into place along the bottom. ( i know,,cheezy,huh) | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Use a long narrow screwdriver, gently push the tabs down so the grill will release. Be gentle because the clips get brittle over time and are easy to break off. Just checked a grille I have, it has 3 clips on the bottom. One is in the center and the other 2 are about 3 inches in from the turn signals. The clips stay with the lower valance and all the grille has are the square slots in it. | | |
