0 members (), 80 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#542082 05/30/2009 3:28 AM
Apprentice
Apprentice
I removed the 5 screws along the top and center of the grill but it is still attached to a plastic piece below the grill. How is it attached and how can I release it? I need to remove the grill to gain access to the A/C condensor.
Kenneth L. Hollingsworth
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
You may want to ask over on ChevyTalk since they deal w/late model trucks also...Joe
My 96 Blazer snaps into place along the bottom. ( i know,,cheezy,huh)
Use a long narrow screwdriver, gently push the tabs down so the grill will release. Be gentle because the clips get brittle over time and are easy to break off. Just checked a grille I have, it has 3 clips on the bottom. One is in the center and the other 2 are about 3 inches in from the turn signals. The clips stay with the lower valance and all the grille has are the square slots in it.
