2 members (NJC, Shade Baby), 145 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#541875 05/29/2009 2:43 PM
I would like to know how much paint would be needed to paint a 2 Ton Chevy 6100 with dump. I would like to paint the body and the exterior of the dump the same color. Will 1 gallon do the job or should I get another quart or gallon extra? Forest Green is the stock color. I currently have one gallon. The dump is now POR15 Black and it states you can paint over this product. Also, what color are the rims stock, green, black?
I would take a pic of the truck to where You are buying the paint and ask them about how much You will need mixed that way it will all match , look at the pics on the gallery should help on the rim color.
Pete
You will also have to tell them what type of spray gun (painting system) you will be using. HVLP systems use less material.
Stock rims were black.
You will have to rough up the POR-15 coating. Will you be using a primer/surfacer?
POR-15 has a product called tie cote to use over it so you can use a top coat over it. It might be a good idea to check into it. I am doing several areas on my truck with POR-15 and bought the tie coat to use over it. I don't want to spend $200-$300 for paint and have a problem with it.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
