| | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | I would like to know how much paint would be needed to paint a 2 Ton Chevy 6100 with dump. I would like to paint the body and the exterior of the dump the same color. Will 1 gallon do the job or should I get another quart or gallon extra? Forest Green is the stock color. I currently have one gallon. The dump is now POR15 Black and it states you can paint over this product. Also, what color are the rims stock, green, black? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I would take a pic of the truck to where You are buying the paint and ask them about how much You will need mixed that way it will all match , look at the pics on the gallery should help on the rim color.
Pete | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You will also have to tell them what type of spray gun (painting system) you will be using. HVLP systems use less material.
Stock rims were black.
You will have to rough up the POR-15 coating. Will you be using a primer/surfacer?
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | POR-15 has a product called tie cote to use over it so you can use a top coat over it. It might be a good idea to check into it. I am doing several areas on my truck with POR-15 and bought the tie coat to use over it. I don't want to spend $200-$300 for paint and have a problem with it. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
