6 members (cmayna, Gdads51, 3B, moparguy, MickeyP, JW51), 110 guests, and 3 robots.
Topics128,064
Posts1,055,861
Members48,428
i put new outer axle bearings and seals on but the small, 2" x 1/8" steel pin(I'm guessing on the dimensions as someone substituted a drill bit for the pin) that goes into the bigger steel pin (looks like a king pin) that goes through the square block of steel that holds the spider gears in place, is broken!
i can't get the old drill bit out as its in pieces, but even worse, i don't know where to get a new one or even the proper dimensions of what I need to buy to replace it.
if anyone knows the dimensions of the steel pin, that'd help a lot. also if you know where i can find one, that'd be great too.
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
Is this the stock axle?
Im guessing if somebody put a drill bit in for the lock pin that the bore it rides in has gotten pretty chewed up. You may want to look for a whole new carrier from another axle to get that part.
Paint & Body Shop moderator
tony,
Sounds like a bag of worms. In the Chevrolet, that "pin" I believe is actually a long hex headed screw. Could someone have broken the screw off, and in an attempt to maybe drill it out, broken a bit off in the hole?
If you put bearings and seals on, it means you must have removed the "pinion gear shaft" (looks like a king pin) to access the clips in order to pull the axles....right!
So now I'm not sure what's going on. Unless GMC uses a pin, this should be a small bolt. It really sounds like this has been broken, and then attacked with a drill. Clean the hole with brak-kleen, grab your trouble light and magnifiers and see what's going on.
My picture shows this as a blind hole...not somewhere you usually drive a pin into! I don't know the size, but I will bet someone on this site does..maybe wrenchbender...keep your fingers crossed.
Stuart
thanks josiah and stuart for the help. unfortunately, i tried reusing the broken 'pin' after getting the bushings replaced. i figured it was holding before... but i thought i'd better try to find a replacement to be safe. then it hit me, why the 'pin' had a sharp edge like a drill bit. because it IS a drill bit shank that's been broken off and shoved in there. who knows how long its been holding like this.
any information on what should go in there and where i might find it would be appreciated by me and my wife, who can't get her van back into the garage until i fix this!
happy new year
tony
if someone can post a picture of what the locking pin/bolt looks like and a possible source or substitute, i'd sure appreciate any and all help! thanks
tony
Riding in the Passing Lane
It is a special bolt that has a short amount of threads with a hex head & a long shaft/pin sticking out. If you had the pinion shaft out you should be able to remove the broken piece from the shaft & make shure the hole in the carrier is clear & if the tthreads are usable. My partner is going down to his salvage yard this week end. He can probably find one & send it to you. Reply or e-mail me [email protected] & I will give you his phone # George
1972 Chevy c10 Cheyenne Super
I have a box of them if you can't find one locally.
[email protected]
My Blog
thanks much wrenchbender for the offer, but I'll save your partner the trouble and see if dave can send me one as he says he already has some on hand.
thanks much to everyone for your help on this. as usual, it turned into more than the simple project i envisioned, but its definitely a learning experience and fun too.
happy new year to all on the board from the mcgowan family!
Apprentice
Apprentice
I had this same problem with a 10 bolt rear end.I wish I had good news for you,but I was not able to extract the broken pin from the spider shaft,the hole was too mangled up.Had to resort to gas axe to get the rear end apart,and replace parts as required.Good luck to you.
