| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54182 12/31/2005 7:22 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i put new outer axle bearings and seals on but the small, 2" x 1/8" steel pin(I'm guessing on the dimensions as someone substituted a drill bit for the pin) that goes into the bigger steel pin (looks like a king pin) that goes through the square block of steel that holds the spider gears in place, is broken! i can't get the old drill bit out as its in pieces, but even worse, i don't know where to get a new one or even the proper dimensions of what I need to buy to replace it. if anyone knows the dimensions of the steel pin, that'd help a lot. also if you know where i can find one, that'd be great too. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#54183 12/31/2005 7:40 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Is this the stock axle? Im guessing if somebody put a drill bit in for the lock pin that the bore it rides in has gotten pretty chewed up. You may want to look for a whole new carrier from another axle to get that part.
#54184 12/31/2005 7:52 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tony,
Sounds like a bag of worms. In the Chevrolet, that "pin" I believe is actually a long hex headed screw. Could someone have broken the screw off, and in an attempt to maybe drill it out, broken a bit off in the hole?
If you put bearings and seals on, it means you must have removed the "pinion gear shaft" (looks like a king pin) to access the clips in order to pull the axles....right!
So now I'm not sure what's going on. Unless GMC uses a pin, this should be a small bolt. It really sounds like this has been broken, and then attacked with a drill. Clean the hole with brak-kleen, grab your trouble light and magnifiers and see what's going on.
My picture shows this as a blind hole...not somewhere you usually drive a pin into! I don't know the size, but I will bet someone on this site does..maybe wrenchbender...keep your fingers crossed.
Stuart | | |
#54185 12/31/2005 6:45 PM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | thanks josiah and stuart for the help. unfortunately, i tried reusing the broken 'pin' after getting the bushings replaced. i figured it was holding before... but i thought i'd better try to find a replacement to be safe. then it hit me, why the 'pin' had a sharp edge like a drill bit. because it IS a drill bit shank that's been broken off and shoved in there. who knows how long its been holding like this. any information on what should go in there and where i might find it would be appreciated by me and my wife, who can't get her van back into the garage until i fix this! :-) happy new year tony
#54186 12/31/2005 8:17 PM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | if someone can post a picture of what the locking pin/bolt looks like and a possible source or substitute, i'd sure appreciate any and all help! thanks tony
#54187 12/31/2005 9:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is a special bolt that has a short amount of threads with a hex head & a long shaft/pin sticking out. If you had the pinion shaft out you should be able to remove the broken piece from the shaft & make shure the hole in the carrier is clear & if the tthreads are usable. My partner is going down to his salvage yard this week end. He can probably find one & send it to you. Reply or e-mail me [email protected] & I will give you his phone # George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#54188 12/31/2005 9:43 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have a box of them if you can't find one locally. [email protected]
See the USA in your vintage Chevrolet! My Blog | | |
#54189 01/01/2006 4:54 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | thanks much wrenchbender for the offer, but I'll save your partner the trouble and see if dave can send me one as he says he already has some on hand. thanks much to everyone for your help on this. as usual, it turned into more than the simple project i envisioned, but its definitely a learning experience and fun too. happy new year to all on the board from the mcgowan family!
#54190 01/02/2006 5:49 PM | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | I had this same problem with a 10 bolt rear end.I wish I had good news for you,but I was not able to extract the broken pin from the spider shaft,the hole was too mangled up.Had to resort to gas axe to get the rear end apart,and replace parts as required.Good luck to you. | | |
