6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#541698 05/28/2009 11:56 PM
Hey Bolters! The engine in my 56 3100 is getting tired and my ace mechanic told me to shop for a new short block. I have what I believe to be is a 59-60 engine - Block #3769716, Stamped ID F0301BE
Any idea on where I can buy a rebuilt short block?
Thanks!
Larry Bear
55.5 Chevy 3100 Panel
I would say You should shop around for a good rebuilding shop in Your area , I am lucky that I live close to Chicago and have many good shops , I do My own work and just farm out the machining it is not as hard as You might think as long as You follow and read the instuctions , there are many good books to help You along the way and of coarse the bolters will help.If You can take it apart You can take the short block to a shop and have it redone than You will know that Your engine is going to give You good service for many years .
Pete
Find a solid engine and have your mechanic rebuild it. That way if something goes wrong, you're covered... or at least you should be if your mechanic is a stand-up guy.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
You might consider Jasper or one of the other reputable rebuild shops. If they have a participating dealer/ store near you they cover the freight.
http://www.jasperengines.com/gas-engines.php
Try the swap meet section on this site or on inliners.org. Of course 235's show up on eBay regularly...
Good luck.
Professional Novice
ccb Offline
Apprentice
Apprentice
here is a complete motor on graigs list in tx http://lubbock.craigslist.org/pts/1191564358.html
ccb #543638 06/05/2009 12:04 AM
Thanks for the leads! Any others??
Larry Bear
check the links swapmeet here I see 235's all the time some for free,
Brad
