2 members (TUTS 59, Maybellene),
157
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54163 12/30/2005 1:28 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Hi I would like to get a bit more speed and a bit less RPMs out of the 40 without changing to an open driveline. Will a later 4 speed 1950 to 1954 help? Or is there a kit to install the saganaw 4 speed? I plan to do Patricks 3:55 rear ring & pinion swap, but when I replace the clutch and preasure plate I wonder if I could/should change transmission also?? thanks Bill | | |
#54164 12/30/2005 1:42 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | All the trannys you listed will not improve your speed as high gear is 1:1 on all of them. Plus you are talking about major surgery to even fit a Saginaw to your torque tube. Why not just make the leap now to open driveline, makes life so much nicer. With the open drive line then you can think about great things like a T-5 overdrive trans. If you must stay with torque tube then just swap in Patrick's gears. | | |
