| | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I have a QuadraJet for a 350 engine. It needs rebuilding for sure. How difficult is it to rebuild one? Is there a lot of Fine-Tuning involved, and does the job require special tools?
I'm thinking of hiring this out, but I'd also like to take a crack at it myself. I'd just like to know what's involved before I make a decision.
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | The biggest problem with QJs is they wear out the body around the throttle shaft. If it's loose and sloppy it will either need a trip to the machine shop or replaced. Other than that is a standard carb rebuild.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | If you want a good book on Quadrajet rebuilding and tuning Carbking posted this book sometime ago "How to rebuild and modify Rochester Quadrajet carburetors" by Cliff Ruggles. I have a copy excellent book. In addition to what 55 tractor said there are also couple of seals in the bottom of the float bowl that need to be checked for leakage. The book also explains that Qjets were tuned for a particular engine and switching to another engines requires retuning the Qjet, it's explained in the book.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | Okay, thanks. Guess I'll just hire the expert on this project. I think he can rebuild it for about $150.00.
