0 members (), 209 guests, and 3 robots.
Topics128,266
Posts1,058,368
Members48,485
#541222 05/27/2009 4:48 AM
Riding in the Passing Lane
I have a QuadraJet for a 350 engine. It needs rebuilding for sure. How difficult is it to rebuild one? Is there a lot of Fine-Tuning involved, and does the job require special tools?
I'm thinking of hiring this out, but I'd also like to take a crack at it myself. I'd just like to know what's involved before I make a decision.
~ davey
1967 Chevrolet 1/2-Ton Pickup
I'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.
I've forgotten more than I ever knew. Okay, where did I put it?
A man can never have enough tools
Lovett #541232 05/27/2009 5:43 AM
The biggest problem with QJs is they wear out the body around the throttle shaft. If it's loose and sloppy it will either need a trip to the machine shop or replaced. Other than that is a standard carb rebuild.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #541269 05/27/2009 1:35 PM
If you want a good book on Quadrajet rebuilding and tuning Carbking posted this book sometime ago "How to rebuild and modify Rochester Quadrajet carburetors" by Cliff Ruggles. I have a copy excellent book. In addition to what 55 tractor said there are also couple of seals in the bottom of the float bowl that need to be checked for leakage. The book also explains that Qjets were tuned for a particular engine and switching to another engines requires retuning the Qjet, it's explained in the book.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #541414 05/28/2009 12:16 AM
Okay, thanks. Guess I'll just hire the expert on this project. I think he can rebuild it for about $150.00.
~ davey
