7 members (Shade Baby, Otto Skorzeny, GIJOE298, 1955 1 Series, Cletus1950, Youngin' Tut 59, MickeyP),
125
Mod | | | Forums66 Topics128,147 Posts1,056,806 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2 Member | | Member Joined: Apr 2002 Posts: 2 | Hi ya'll, I'm done with trying to keep this canister filter from leaking. Can anybody tell me where I can get the adapter to use a spin-on? Last time I had the canister off, I looked, but didn't see the mounting holes for an adapter like for the early V-8s.
Thanks Ken
Kenner
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I just took mine apart and found the regular gasket at the top, but when I started cleaning it I found another narrower gasket that I am not sure yet where it goes as I haven't put it back together yet (looking for proper color orange). Maybe you are missing one of the gaskets. These housings look pretty leakproof to me.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | Ken, I think most good part stores will sell the adaptors for the spin-ons. In order to use them, however, you have to tap into the block. There's a particular spot on the old sixes that had a pin that can be removed, and you can tap into that passage to feed oil to the spin-on, but I don't recall exactly where it is. Maybe someone who recalls it could chime in here. | | | | | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | a lot of cannisters leaking is caused by a accumalation of old seal rings still in the o ring groove that have not been removed. get a sharp pick and remove all the old o-rings and make the o-ring groove clean wet your new o-ring with oil and install in the groove 1st then install filter and cannister remember the thru bolt seal too
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#5412 04/12/2002 10:50 PM | Joined: Apr 2002 Posts: 2 Member | | Member Joined: Apr 2002 Posts: 2 | Ok Cool, Your right baldeagle, there are no good parts stores here,lol. I'm not ready to tap into the block yet, and thanks bullfoot. I'm sure it can use a good cleanin. I am only aware of the one o-ring, (kinda square) that seals. Any time in past (v-8)cannisters. If you had two, thats why it was leaking, the top being left from the last filter. Does the v-6 have two? Anyway, I'll clean the crud out, and see if that takes care of it. It should'nt have much with only 61,000 on it.........right,lol.
Thanks again, Ken
Kenner
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Usually orings aren't square, that could be your problem. They take the shape of the groove after a while and they should always be replaced if they no longer have a round crosssection.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | i called me parts guy up and he looked in de 305 v6 oil filter box and de oring is round. i have picked as many as 6 orings out of de groove before
