1 members (delwrench),
95
Mod | | | Forums66 Topics128,174 Posts1,057,047 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | I have replaced the wheel, carrier and pinion bearings in the 68 3/4 ton chunk I put into my 1 ton rear (5.14 to 4.11). I replaced these bearings because of a rumble coming from the rear. Changing the bearings cured the rumble but let me hear a terrible whinning from the rear. VERY annoying! The ring gear and pinion gear are pitted and rough and I guess I will replace them both as the shop manual says the noise can come from rough or pitted gears. Question: Can anyone advise where I can find a 4.10 ring and pinion set for a 68 chunk? Any of our sponsers? How hard is it to change the gears relative to replacing pistons for example? Thanks | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Swapping the gears is a lot tougher than building a stock 6. You need to take a close look at the shop manual. If you have and know how to use a set of dial indicators you should be able to do it. If not, find someone to help. Last time I checked some of the vendors carried the 4.10 gears. I would avoid Houser like the plague, he doesn't know much about these trucks. Randy\'s Ring & Pinion also makes a set of 3.90 gears.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | Not sure but you could try Patricks. There is even a story somewhere here about installing one of thier kits but you would have to search for it.
Send David Hicks home - now! "Better to be wrong and kill no one then right with mass graves" Albert Camus
| | | | | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | | | |
#5406 10/23/2002 12:18 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Replacing those gears requires patience, attention to detail and a little skill. Read and understand the procedure in the shop manual before you begin. As Fred says, you will need a couple of special tools, don't try to "ballpark" anything..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Machinist's bluing will let you easily check the contact pattern and if that is good it will last a long long time even if it ' sings ' .
I usually drop a small rare earth magnet in the bottom of the axle housing to catch any wear particles .
Keep it full of clean 90W hypoid gear oil & change annually etc.
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
