Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (TexasA&M48Truck, baldeagle, cmayna), 77 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
Help!!! Just turned on my headlights and gauge just pegged to discharged,went to park and returned to normal. Any sugestions?????
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
use an ohmeter to check all the wiring for starters, likely be a shorted wire between the switch and the lights, not likely the actual switch
red58 I know what you ment to say but as it is written you have this guy checking his starter wiring. LOL
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
So splain this to me a bit more. You turned the headlamps on and the amp meter went to complete discharge and stayed untill you went back to the running lamp position (park). Is that right? Did you turn them on again? If so what happened? Are they ok now or do you still have the problem?
still have the problem even after I turned them off and went to park lights.only happens with headlights on.Checked all wiring no grounds.
1953 Chevy Two-Ton
I don't know what year of truck you have but the dimmer switches can cause big problems. If you were checking for shorts to ground I would be checking the wire that goes from the headlight switch to feed the dimmer switch, with everything still attached. If you start to remove wires you might alter the problem.
1951 1 Ton Completed
It's a '53 6100 with 12 volt generator conversion,I might have a
6 volt switch but I don't know,I could check with my ohms meter if I knew what my readings should be.
1953 Chevy Two-Ton
voltage doesn't matter for switches, will work the same with 6 or 12 - should be open on one set of contacts [the "off" side], dead short on the other [the "on" side], opposite when switched
Ok, so you either have a dead short or weak amp meter. Most old trucks have a fuse built onto the side of the switch. Remove this fuse and try turning the headlamps on again. Do you get the same result? If so you may have a faulty switch if not install the fuse and goto the headlamp dimmer switch on the floor. on this switch you will have 3 wires, one gos to the headlamp switch the other 2 are for high and low beam. Before we test (just for grinns and giggles) mash the dimmer 1 time and try the headlamps again. Did the meter peg out? I am stoping here for a reply.
Did'nt matter what I did with the dimmer,but if I leave them on for a while they start to flicker like I'm turning the switch on and off.
1953 Chevy Two-Ton
almost for got could'nt find a fuse.
1953 Chevy Two-Ton
PapaJ,
Don't rule out the voltage regulator. It might have funky points that aren't allowing the generator to kick into charge when the headlight load is applied. A massive discharge indicated by the ammeter would produce smoke and fire if it were a short. If it were merely a heavy draw on the battery caused by a 'no charge' situation in the charging system, it would go on until the battery was dead...no fire-no smoke.
Stuart
New voltage regulator,new battery still draws.Generator was putting out good voltage too.
1953 Chevy Two-Ton
Sounds like your switch has a circuit breaker built in. I don't know what year they started that but all headlamp switches after a certain year have a built in circuit breaker. It will get weak and start shorting out. You can't do much to test this but you can look over the wiring system for any obvious damage and replace the switch.
After back surgery and dealing with legal stuff I got to return to my light switch.Turns out I'm an IDIOT,I cut the electrical tape off of the"wiring harness" and found a bunch of exposed wires for the headlights.So now that I know what the problem is I can fix it!(just a few slaps upside my head.)
1953 Chevy Two-Ton
The AD series of trucks had a thermal breaker built into the head light switch.
Good luck on your repair and I hope you are feeling better.
Just have to rewire at the terminal block to the headlights.
1953 Chevy Two-Ton
