6 members (Rusted Nut, FAST55, KEVINSKI, Wally / Montana, HandyAndy, 1955 1 Series), 47 guests, and 3 robots.
Topics128,090
Posts1,056,018
Members48,430
#540001 05/22/2009 2:30 PM
Only thing left on chassis before blasting is rear spring pins. Welded a nut to slide hammer adapter similar to shop manual tool. Neither budged and nut threads (fine) stripped. Help!
Should have mentioned it's a 57 3100. Pin can't be driven toward the chassis, and no room to get behind it to drive it out.
I don't know what type of truck you have but on my 1 Ton, there is a lock bolt. After removing the lock bolt I was able to drive the pins out from the backside. I didn't use a puller.
1951 1 Ton Completed
Hello!
The last time I had to do that I used an air chisel, and from what I remember they came out without too much problems.
Come to the Great Lakes GABfest
Get all the details here!
as mentioned before just remove the tapered lock bolts ,take nuts off and drive out with a punch carefully so you can reuse them .if the main pins are froze in the spring or hanger or shackle ,year's ago they had a adaptor that you took out the grease fitting and screwed in were the fitting was and used a slide hammer to coax it out .but i haven't seen one for awhile .
I had one that was a booger! Used just about every penetrating fluid with no success. Heated it, drove right out. Have fun and good luck
Dan
The hard part for me wasn't the pin, it was the lock bolt. I used a little heat to encourage the bolt to move on out.
On my one-ton, the frame has holes that line up with the spring hangers. Once the lock bolt is removed, you should be able to either drive them out from inside the frame, or drive them in from outside the frame (whichever offers the easier access).
Lane
That's what the shop manual shows. My adapter used the lock nut instead of the small grease fitting threads. Seems like that would easily break. But the nut adapter didn't work so maybe I'll try the smaller adapter. Thanks.
Did you heat the pin or the housing? BTW I'm not too far from you, just south of Amsterdam.
