7 members (Gdads51, 55shaker, greenie-reddy, UtahYork, 3B, Peggy M, joe apple),
125
Mod | | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | I'm trying to replace the turn signal components but don't have a clear idea of what components I need to buy. The truck I got was stripped out of the old stuff. Anybody know where I might be able to find a "clear" diagram or photos on how the turn signal components mount in the steering column? I've got the factory shop manual and I can't find a detailed procedure on how to replace it. I also have the factory assembly manual but those pictures don't help much either.
From what I can gather, there's the switch, mechanism assembly, cancelling plate, mount bolt, and lever. I just don't know what to buy and how they install. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I think this link is blocked.
| | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | yep, seems like there's nothing in the galery. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | A member Ken 1960 emailed me a diagram about a year ago. I may still have a copy of it in my truck,I'll have to look. Maybe he can send you a copy if you contact him. It was a nice diagram of all the parts and was very helpful. I still can't figure out the turn signal cancelling mechanism, so I just do it manually. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | On the GMC models, they seem to be NO replacement parts made due to the fact that the steering wheel hub is slightly different than the chevy's? I have a 4 sp hydramatic, it seem to me that there were other truck/cars with the 4 speed hydramatic used during those early years. So there must be something I could re-use in order to make mine work? I have to hand cancel the signals like a lot of other folks. Of all the things that will keep me from having an almost 'perfect truck" (HA Yeah right). | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | V-6 Fix Modelman, Did you try Pauls's GMC parts, maybe you could call or email him and see what he says. I hand cancel mine too, it's no big deal but it would be nice to correct that. I think I have all the parts but gave up trying to get them installed. Enjoyed looking at your Webshot Album. Happy Memorial Day! Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | 61 cheevy I sent u an e-mail, scan of diagram
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks Cal 55,
I've give him a shout. Jake
