3 members (Southerntruck, Hanks custodian, KEVINSKI), 123 guests, and 1 robot.
Topics128,162
Posts1,056,933
Members48,458
Junior Member
Junior Member
im trying to get my truck running and i noticed i can only shift into reverse i have a 4 speed 235
anyone know why this might happen and how to fix it thanks alot merry xmas
3B Offline
Hy medicmax11769, Are you talking about a transmission that is just sitting in the truck and your trying to shift it without the engine running?
Junior Member
Junior Member
sorry engine not running im working on that yeah tranny is sitting in truck engine is not locked up
3B Offline
Hy medimax11769, So many things it could be, just the fact that the gears are sitting still and not changing their relationship to one another, it could be the shifter itself, but I don't think so because it will shift into reverse, it could be the shift rails inside the top cover. Try turning the engine by hand a bit and see if you can find any other gear,hope this helps.
Or, even roll the truck back and forth a little bit instead, or in combination with turning the motor by hand. And it could also be that somebody took the top cover off and didn't line everything up properly when they put it back on.
Junior Member
Junior Member
i got to check the cover i think its flapping in the breeze also can this be caused by a buckled clutch
Not likely.
