8 members (Bill Hanlon, rfs56trk, Hanks custodian, BarryP, UtahYork, Donf, Frank50, Gazz),
123
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53919 12/24/2005 4:43 AM | Joined: Dec 2005 Posts: 24 Junior Member | | Junior Member Joined: Dec 2005 Posts: 24 | im trying to get my truck running and i noticed i can only shift into reverse i have a 4 speed 235 anyone know why this might happen and how to fix it thanks alot merry xmas | | |
#53920 12/24/2005 5:45 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy medicmax11769, Are you talking about a transmission that is just sitting in the truck and your trying to shift it without the engine running? | | |
#53921 12/24/2005 6:04 AM | Joined: Dec 2005 Posts: 24 Junior Member | | Junior Member Joined: Dec 2005 Posts: 24 | sorry engine not running im working on that yeah tranny is sitting in truck engine is not locked up | | |
#53922 12/24/2005 7:31 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy medimax11769, So many things it could be, just the fact that the gears are sitting still and not changing their relationship to one another, it could be the shifter itself, but I don't think so because it will shift into reverse, it could be the shift rails inside the top cover. Try turning the engine by hand a bit and see if you can find any other gear,hope this helps. | | |
#53923 12/25/2005 12:49 AM | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Or, even roll the truck back and forth a little bit instead, or in combination with turning the motor by hand. And it could also be that somebody took the top cover off and didn't line everything up properly when they put it back on. | | |
#53924 12/25/2005 8:34 AM | Joined: Dec 2005 Posts: 24 Junior Member | | Junior Member Joined: Dec 2005 Posts: 24 | i got to check the cover i think its flapping in the breeze also can this be caused by a buckled clutch | | |
#53925 12/25/2005 7:52 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | | | |
