2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53911 12/24/2005 4:01 AM | Joined: Dec 2005 Posts: 5 Junior Member | | Junior Member Joined: Dec 2005 Posts: 5 | Hello I have a 67 Chevy short step & am trying to decide if I should keep the 250 six thats in it or use the 292 six I have in another truck (a 67 GMC long fleet)Plan to keep the Chevy & sell the GMC The 292 seems to run smoother than the 250 & have been told they're better motors So far have rebuilt the front end & rear end, power steering & power assist brake master & put in a turbo 350 trans any advice will be appreciated | | |
#53912 12/24/2005 5:52 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy step67, If the truck was never equipped a 292 from the factory it would involve a lot of fabricating to install it, if it would fit at all, different mounts are needed and it is physically taller than a 250. Hope this helps you make up your mind, I'm not trying to scare you just make you aware of whats involved. | | |
#53913 12/24/2005 6:37 AM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | The 292 was an available option in your truck. It mounts a bit bifferent so it'll take a little work to convert, but not to bad, if thats what you decide to do. To convert or not depends on what you want to do with your truck. If you are going to tow anything or routinely haul stuff, I'd say go with the 292 for the extra low end torque of the truck motor. However, the 250 is a better hot rod motor. The best way to get horsepower from a small displacement engine is wind it way up. For example my 1100 cc motorcycle engine makes 120 horses, but ya gotta wind it 9000 rpm! The shorter stroke and lighter crank of the 250 allow you to wind it higher quicker without a bunch of custom work, and the 250 is still a 7 main bearing engine, so it is very tough. Go over to the Inliners International site and check out what some of the guys are doing. On this board, even though it is called Stovebolt.Com, you'll find a lot of resistance to actually using a stovebolt motor in your truck.
Boo
We don't need no stinking V-8s!!
#53914 12/24/2005 2:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have both trucks there it should be an easy swap. Both engines were available in those models. The 292 is a tougher engine. It was built for trucks. The only weak part is the stock exhaust manifolds. When driven hard they will warp, crack, & burn out gaskets. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#53915 12/24/2005 5:04 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The biggiest problem you will have is the power steering brackets. The 292 block is 1 3/4 taller than the 250. The Alternator bracket will have to me moved up. There are at least two different alt brackets, one appears to be cast and the other two pieces of steel welded. My .02 Larry
I don't own a vehicle that isn't old enough to drink. | | |
#53916 12/25/2005 1:31 AM | Joined: Dec 2005 Posts: 5 Junior Member | | Junior Member Joined: Dec 2005 Posts: 5 | I want to thank all,for your advise. Since I have both trucks the mounting of the engine shouldn't be a problem I can swop mounts etc. from one truck to another. The 292 has power steering on it as well as Larry mentioned. Basically I want the more reliable way to go (most people tell me get a V8) but as Boo stated we don't need no stinking V8. | | |
#53917 12/27/2005 4:20 AM | Joined: Dec 2005 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 47 | i switched from a 250 to 292...they both run about to same to me..the 250 could whine up little faster but doesn't have the torque the 292 has..
1966 Chevrolet C-10 1971 Chevrolet Camaro RS 1989 Pontiac Bonneville MY GARAGE...www.dragcitygarage.com
#53918 12/31/2005 6:11 PM | Joined: Dec 2005 Posts: 10 Junior Member | | Junior Member Joined: Dec 2005 Posts: 10 | I have a 292 in my 65, and no disrespect to the 6 cylinder. I plan on putting in a 454. But I do have to say the toughest engine I ever had was a 6, it was in a dodge truck a 225 slant 6. Ran without oil and water for about 70 miles and all it done was crack a head,burn up the water and oil pump. I put a new head on it, both pumps, and checked my bearings, filled it up with fluids and went another 80,000 with no problems.
Keep it between the mayo and the mustard!!!!!
