| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | What would be a good middle of the road bead blaster to purchase for cleaning small parts? Lots of rust removal. http://community.webshots.com/user/53jimmy
The best things in life are FREE!
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | There are lots of different brands out there. I have one of these http://formula.guyson.net/home.php I am very pleased with it. I don't like anything made in Asia. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 53Jimmy, what ever you buy you will always wonder why you didn't get one bigger....right when a part you need blasted will not fit into the cabinet.
It depends on what you want to spend. I personally bought a 46"X 28"X28" cabinet from TPtool with the Vac-35 attachment. I shelled out about $1100 in 2001 but it has been a really nice investment. It has held up extremely well to my almost commercial use of it. This size has the bigger window and two lights inside. The price has stayed about the same and sometimes they run them on sale.
I buy my plastic stuff to protect the inside of the window from a bulk supplier of mylar. Get it in a roll for cheap. I use glass, sand and plastic in the cabinet. No problems. The size may also depend on your air compressor. I blast at 90 psi and it does a good job. They have other sizes available so compare them ALL before purchasing. Some guys make their own and they do a good job.
| | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | I own a similar model from TP, i believe they are called Skat Blast Cabinants. Made in the USA and TP can get all of the parts. Plus, at least for me, they are only about a 2 hour drive away. I agree with Achipmunk about getting a large one . It's a great piece of equipment. TP Tools | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Hey, check these guys out. www.badboyblasters.com Got some nice lookin stuff. I think thier brother owns Eaton commpressor. Best in the biz. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Before investing in a blasting cabinet be aware that you will need some sort of vacuum device to go along with it and if you think you can get off cheap, think again. A good, dependable, LONG LASTING, vacuum is a must.
Blasting cabinets generate large volumes of mico-fine dust that clogs conventional filters (like shop vacs) very quickly and it's extremely frustrating to have to stop work to clean an inadequate filter only to have to do it again soon after.
Another less critical but important feature is a hopper at the bottom for emptying the abrasive so you can change blasting media quickly.
BadBoy has a what appears to be a nice unit for $800 and it includes a vac.
Of course, you will have parts that are too big for whatever you buy so find a tombstone company that will blast those for you. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | make sure you have a full loading door, front loading would be prefered. side limites access on the larger/longer models. as nice as snap-on tools are my 356 porsche shop owner wished he had NOT bought his. the beads do not fall and fill the bottom hopper well. the compressor is the key to a good blaster.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | check the local auction houses. I helped a friend load up a hotsy and a blast cabinet with vac filter and a small welder he got an an auction for the grand total of $500. Missed out on a few other things. As small shops and companies downsize or close their doors, there are good deals to be had.
| | | | | Joined: Jan 2018 Posts: 1 Moderated | | Moderated Joined: Jan 2018 Posts: 1 | If you have a bit to invest, and want to get a bead blaster that is durable (and doesn't leak blast media like a sieve), we use this blast cabinet from Raptor Blaster at our own shop. Cleans rust right off of smaller parts in a jiffy. | | |
