Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Donf, Shof, Peggy M), 131 guests, and 3 robots.
Topics128,281
Posts1,058,488
Members48,490
#538959 05/18/2009 7:29 PM
I have a 3/4 ton 1946 Chevy longbed pickup. I am running a 261 motor and have recently replaced the old unsynchrnized tranny with a Borg Warner T-5 five speeed, had a new drive shaft made and balenced then replaced the 4.56 ratio third member withqa 4.11 taken from a 1965 3/4 ton. I am getting the speeds (about 65 MPH) that I'm looking for but still getting allot of vibration. Anybody ever run into this situation. Can anyone give me a hint where to start?
rechecking the balance or maybe the drive shaft angle. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Here's some tips and info for checking and setting up your drive-line angles:
http://www.stovebolt.com/techtips/driveline/setup/index.html
Are your tires balanced and round?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
If the (I assume two-3/4 ton) driveshafts are not phased properly it could cause vibration.
Good luck
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
